considering reconditioning my engine. mk5 1997 non turbo 2.5 with stuffed bottom bearing
(Year: 1997
Make: FORD
Model: TRANSIT
Colour: White
Submodel: 190 DIESEL LWB Custom high roof single tyre rear axle
VIN: SFALXXBDVLTE02811
HB series 76hp 56kW)
the worst case scenarios, according to my mechanic
1. that the conn (connection) rod is worn beyond tolerance
2. cam is too worn
3. STATE of, OR cracks in engine head? (but he said we would see water in engine)
is there a shop online or otherwise in some corner of our globe which still stocks the gasket kits, seals, valves, rockers, cams ?
not sure what state of the cylinder head is. and when we take it to bits what will we find??? WE MAY FIND A PERFECT ENGINE. LESS A BOTTOM END BEARING? its got 300K on clock, and worn cyl walls?
if you are willing to share where in UK, or WORLD these parts are found?
I imagine there are mechanics with whole sets of heads, rings, cams and gaskets just sitting these and prob brand new. have found camsahft seal,see below
looked on EBAY UK and most searches on NEW are nIL, and mk5 is no longer held new. (like on transitPUK )
I love my van and given the huge cost of other vans which are usually low roofs and the complexity of the diesel pumps in them, my vans is mostly all in great nick with minimal rust.
i love the mnual bosch pump as well. I can get lots of smileys for parts for all the other items. I have 3x MT75 gearboxes. but just this engine.
I have looked for second hand engines, but they are usually with BLOWBACK and or uneven compression and or higher kms and or all of the above and poorly maintained.
Maybe you have a 1km transit engine sitting in your garage that is fully reconditioned and you want to move it on. ??? lol
ALSO found motor doctor UK see below
thks
Rick
