MinorMatt wrote:I have a good used mk4 one on the shelf
Keef wrote:Looks like someone's used a hacksaw on the end of your plug?
If the connectors fit through the holes in the plug and you know which pins they connect to you could push them through the plug and connect them up before connecting the rest of the plug maybe
digitalimager wrote:Keef wrote:Looks like someone's used a hacksaw on the end of your plug?
VASELINE!
Reggie1 wrote:Hi
Just by chance do you still have TPS.
I'm in Australia can't get them here. I have the Lucas 54408439a TPS which throws up codes as reading on ecu inlet pins are show one pin outside of resistance levels.
Wait to here from you
Rodger
