HI all, I've read every post on this forum about torque specs for the rear hub bolts and I'm still not 100% confident. So just wanted to check the following is what everyone else would do...
Mk3 1988 twin rear wheel.
I'm going to tighten the inner bolt (65mm in my case) until it's tight and there's no play in the wheel, then back it off until the wheel has the very slightest play. Then pop the lock washer on, then then outer bolt tight until the play is taken up. Then fold two edges of the lock washer over so the bolts can't move.
Does that sound right? I'd rather not mess this up.
