So I bought a Transit.
It is a 1994 Mk4 LWB 100hp. It used to be a command car in the volunteer fire brigade in my community and as a member of this fire brigade I have driven this vehicle under blue lights and siren so I know it a little bit and when it was replaced with a new vehicle last month I decided to buy it.
The Transit is in very good shape, it only has 18000 km (about 11000 miles) and is nearly rust free, the only thing I have found is 2 places on the rear wheel arches that need fixing.
The plan is to change it into a simple camper for me and my wife, I must start with removing the blue lights, siren and markings from the fire brigade so that I can register it as a private vehicle and remove everything from the inside and start building a camper.
I have been trying to decode the build plate to figure out what I have bought an here are some of it:
Engine: 2.5L turbo diesel 100 hp
Gearbox: MT 75 5‐speed Wide Ratio
Rear Axle: 51A Heavy Salisbury
Rear Axle Ratio: 4.63:1 Looks like it might have a LSD (have to confirm it)
Suspension: Optimized for high centre of gravity vehicle
Wheel Base: 3570 mm
Gross Vehicle Mass: 2900 kg
The plate says that it is type 100L but the weight numbers that it is type 150L, I don't know what is the difference.
Then it has another plate that has codes for S.V.O. "Special Vehicle Orders" but I have no idea what they mean.
I am surely going to ask some questions here, look forward to communicate with all of you here in the future.
