The hub to which assembles visco of the radiator fan. Is pressed into a bearing which is located in the oil pump housing.
Flange viscose radiator fan fits Transit MK3 MK4 MK5 vintage produced from 1986 to 2000 engines 2.5 Diesel and the 2.5 Turbodiesel
V184 wrote:i would imagine you will have to remove the oil pump cover and press it off/on or try a bit of heat
Chug wrote:get a crankshaft seal too if you're gonna take the cover off.
Wipeout wrote:Chug wrote:get a crankshaft seal too if you're gonna take the cover off.
Yes ! I ordered it already with the paper gasket that goes with the cover...thanks anyways for the advice. Tomorrow im gonna start the job, I hope the crankshaft pulley comes out easy, as well the crankshaft sprocket...Any recommendations around this ?? (Im gonna mark everything as much as possible to put everything back in the same place..)
Wipeout wrote:Update:
Managed to take old flange out, with an improvised "extractor" made with one nut (size of the fan nut, screwed in the threaded part of the flange) welded to another nut. Then with a bolt we could push out the old flange...
Finally we pressed in the new flange, now im waiting for the oil pump cover paper gasket and front camshaft seal.
(I needed to order them in the official ford shop, spent like 50eur for both original parts...)
For this 99' 2.5DI smiley the parts number were:
-1077534 gasket
-1539755 seal
Hope one day this post might help someone else.
-1077534 gasket
-1539755 seal
