1999 2.5 TDI starting issues
Postby jordy91 » Fri Nov 11, 2022 11:14 pm
when i go to start nothing happens other than a single click coming from the drivers footwell .
ive read about both starter inhibitors and relays and obviously the starter motor but I cant seem to find the location for the former 2 .
anyone else had a similar issue ?
jordy91
Re: 1999 2.5 TDI starting issues
Postby Chug » Sat Nov 12, 2022 11:03 am
Firstly, Does the starter work with a direct feed to rule that out, then there are fuses under the battery tray on the inner wing and relays under the passenger cubby hole in the dash, and fuses and relay in the main fusebox.
Chug
Postby Noctule » Sat Nov 12, 2022 1:05 pm
check the relay and fuse in the black fusebox mounted next to the injector pump, it might have got flooded
2012 Mk7 125t350 camper conversion in progress
2006 Mk7 115t350 van (cheap tax tramp)
Previously...
Mk5 190 HiCube DRW self-built camper
Mk5 100 swb Custom
Mk5 190 lwb x3
Noctule
Users browsing this forum: Google Adsense [Bot], romperstomper1
