Hi there
What size fuel line is a proper replacement for the low pressure fuel lines on a 2.5TD? The quick clip on the fuel pump end has broken on the line between the fuel lift pump and the filter - doesn't seem the pipe is available off the shelf anymore so need to make one up.
Presumably jubilee clip fine on the pump end and then something along this line on the fuel filter end (don't know if they all do but mine looks like it's a threaded fitting with a nut): https://www.flexolite.co.uk/products/fp ... -nptf-5-16
Anything else I need to know before making up a new line?
Thanks in advance
