valve damage
snapped cam belt
Postby gra26264 » Sun Jul 16, 2023 11:21 am
My cam belt has snapped. I want to try to repair it myself,where do I start, I need a tutorial or a video or something, can anyone give me some tips please.
gra26264
Re: snapped cam belt
Postby dumper » Sun Jul 16, 2023 11:30 am
viewtopic.php?f=18&t=56801 Have a look at this
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
valve damage
Postby gra26264 » Sun Jul 16, 2023 3:05 pm
If my cam belt snapped at approximately 50 mph what damage to the valves etc can I expect to find
gra26264
Re: valve damage
Postby dumper » Sun Jul 16, 2023 3:12 pm
See pm
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Re: valve damage
Postby gotgcoalman » Sun Jul 16, 2023 3:43 pm
Usually no internal valve damage.
A rocker or 2 might be broken and in my experience,5 push rods will need straightened out.
Make sure when timing up you get the hole in the flywheel that goes all the way through when pinning it.
Sent from my ONEPLUS A6003 using Tapatalk
Too bloody quiet :shock:
gotgcoalman
Re: valve damage
Postby gra26264 » Thu Jul 20, 2023 6:00 pm
I have started the strip down to replace the cam belt and have discovered 2 broken rockers and some bent rods,is the disassembly of the rocker shaft straight forward or is there anything I should be careful of? Also as the belt snapped is the retiming of the cam/crank etc easy to sort out? thanks
gra26264
Re: valve damage
Postby gotgcoalman » Thu Jul 20, 2023 6:06 pm
Just make sure you pin the hole that goes right through the flywheel.
There's 2 at 180 degrees to each other.
One is blind and one goes right through.
gotgcoalman
Re: valve damage
Postby gra26264 » Thu Jul 20, 2023 8:09 pm
gotgcoalman wrote:Just make sure you pin the hole that goes right through the flywheel.
Cheers
gra26264
Re: valve damage
Postby gotgcoalman » Thu Jul 20, 2023 8:36 pm
Rocker shaft for spares (just in case).
Stripping is straight forward.
gotgcoalman
