MK4 differential bearing part number
Postby QuebecTransit » Thu Jul 20, 2023 3:10 am
Hi all, I'm trying to find the part number for the MK4 differential bearing kit. I'm in Canada and my differential is whining a lot.
I'm also trying to find a website that has them in stock.
Regards.
QuebecTransit
Re: MK4 differential bearing part number
Postby MinorMatt » Thu Jul 20, 2023 3:24 pm
Which diff type?
rebuild kits are readily available on ebay, but unsure what the part numbers are
Lucas Laser 2000 & IDS
95 N Hallmark (white)
96 P 150 TD 100PS LWB Hi-Top
96 P Autosleeper Duetto
2 x 2006 Mk7s
Postby QuebecTransit » Fri Jul 21, 2023 1:34 pm
I'm not sure how to figure out my diff type.
Issue is I'm in Canada and Ford Canada is absolutely 0 help.
VIN is : WF0AXXGBVAXY28525 (if that helps).
Issue is really that Ford Canada is telling me: "I don't know this vehicle, go f*** yourself!" (it's imported from France as it was never sold here).
Edit: I've ordered the Haynes manual. Hopefully it has diagrams showing part numbers. Otherwise is there another ressource to figure out part numbers?
QuebecTransit
Postby QuebecTransit » Fri Jul 21, 2023 3:45 pm
follow-up. I appear to have a 4.63 differential.
Now... does anyone know if the axles are compatible with the Dana axles available in America?
QuebecTransit
Postby QuebecTransit » Fri Jul 21, 2023 6:29 pm
Yes... I know, I keep posting on my own thread!
I found this. I'm not sure if it will fit though. Anyone here have the expertise to help me?
https://www.ebay.com/itm/185770699769
QuebecTransit
Postby Chug » Fri Jul 21, 2023 9:46 pm
Look on Catcar for part numbers using your Vin number at the top of the page here https://www.catcar.info/ford/?lang=en
to find the axle type use your VIn plate and ID it here viewtopic.php?f=31&t=10363
Chug
Postby QuebecTransit » Sun Jul 23, 2023 3:38 am
Thanks for the help! Got everything I needed except for my exhaust manifold and gasket. Part numebers 6191338 and 1056838. Can't find someone who ships to Canada. Might have to try finding someone who welds cast iron.
QuebecTransit
