1997 DTCs Possibly injection pump and EGR ?
Postby heehawdafty » Fri Jul 21, 2023 5:13 am
Hi there
Got an old 1997 2.5 its come up with the following codes (Autel MaxiCOM MK808BT PRO)
not tried it with forscan yet.
Initally the first symtom was increased engine speed, start the van give it some throttle and the engine speed would stay approx 1500-200 rpm
Shut off, unpluged TPS still the same.
Reconnected tps then it would go into limp mode after about an hours driving.
Anyone hade these symptomps before been years sinec i worked on these.
DTC ( 9 )
PCM (Powertrain Control Module) ( 9 DTCs )
DTC Description Status
P0400 EGR(Exhaust Gas Recirculation) system flow malfunction CMDTCs
P1173 O2S-Inversion CMDTCs
P1177 Synchronization CMDTCs
P1180 Fuel delivery system malfunction-low. CMDTCs
P1182 Fuel Shutoff Solenoid CMDTCs
P1189 Fuel pump speed sensor / wiring CMDTCs
P1256 Pedal Correlation PDS(Pedal Demand Sensor) 1 and HPDS(High pedal demand sensor) CMDTCs
P1257 Pedal Correlation PDS(Pedal Demand Sensor) 2 and HPDS(High pedal demand sensor) CMDTCs
P1644 Fuel Pump speed control circuit failure CMDTCs
Cheers
heehawdafty
cron
