Two different plungers for Lucas Epic
Postby medgalys » Wed Jul 26, 2023 7:08 am
What is the difference between these two plungers for EPIC pump?
https://injectionpumps.co.uk/product/lu ... d-plunger/
https://injectionpumps.co.uk/product/lu ... unger-kit/
The second one is a kit, but I had to use my old spring because with the one included the engine didn't even start.
My original plunger is more similar to the first one and changing to the second one only solved my issue partly so I wonder if it's worth it to try the first one too.
medgalys
Re: Two different plungers for Lucas Epic
Postby MinorMatt » Wed Jul 26, 2023 4:11 pm
The kit has a plunger from a mk4 (DSA947) pump. Its a smaller diameter and won't work correctly in the mk5 pumps
Lucas Laser 2000 & IDS
95 N Hallmark (white)
96 P 150 TD 100PS LWB Hi-Top
96 P Autosleeper Duetto
2 x 2006 Mk7s
