2.5 TD Oil Filler Cap Breather
Postby meterreader » Fri Aug 11, 2023 1:27 am
Ive been messing and made a mess! I removed the existing pipework and replaced with different air filter. Consequently lost the connector for the oil filler cap breather hose. Worked fine whilst I was living on acreage but when I moved to the city is making a hell of a mess on the drive. Where did it connect to? I think it was between the turbo and the inlet manifold. Am I correct?
meterreader
Re: 2.5 TD Oil Filler Cap Breather
Postby Chug » Fri Aug 11, 2023 9:04 pm
Yes it basically goes back to the inlet manifold, but you could just fit an oil catch can to it.
Chug
Postby meterreader » Fri Aug 11, 2023 10:09 pm
Thanks for that. Shouldnt be too difficult to get a connection in to pipe. Will investigate this week.
meterreader
