by dumper » Wed Aug 23, 2023 3:19 pm
Fill the new filter as full as you can I keep tapping it to get air out of it then make sure you have pushed it up square and all the way up I have had a problem with this once and had to remove the filter head and push the head down onto the filter to seal it when fitted start the engine on half throttle and run it for two minutes and it should clear any air .I always do the filter before I do a oil change not at the same time so not to start the van with the oil filter empty of oil .
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
