Just failed MOT for too much play! Was fine last MOT - 2,500 miles ago.
I don’t have either the tools (reamer etc.) or experience to do it. Need an old hand pro with a decent garage, ideally reasonably local.
Any suggestions please?
Altransit wrote:You may know this already, but whenever my kingpin equipped vans were due for MOT, I used to fill them, immediately before, with the thickest grease that I could lay my hands on![]()
When I did have to have them changed, it was always a massive problem getting anyone with the tools to do it
gotgcoalman wrote:Trying to swing a BIG hammer in the wheel arch to tap the old ones out was always an issue
Done em on a MK2 and a MK3 many years ago.
One person heating with a torch and another bashing away.
Was it "play" or "lift" they got you on?
dumper wrote:What did they actually fail it on was it lift or rock when I was presenting hgvs for test on some models if you removed the bushes in the stub axle they would still be within the limits to pass the test they used to fail easier on kingpin lift.there are different limits for kingpin’s based on wheel diameter.they may have failed it on just feel and not on the limit in the tester’s manual.
if it was mine I would show me on what limits they have failed it on.
What he saiddumper wrote:Take it back talk to the usual tester when he’s back off Hoiday.
ColinJack wrote:dumper wrote:Take it back talk to the usual tester when he’s back off Hoiday.
Tried that today and apparently he came back from holiday and resigned!
Altransit wrote:ColinJack wrote:dumper wrote:Take it back talk to the usual tester when he’s back off Hoiday.
Aww bu99erMaybe he heard that you were coming back for a re-test
I can remember taking my old Sherpa to 4 different testing stations to find a tester who knew what kingpins were, and understood that they all have a bit of play
gotgcoalman wrote:are there any Council run Mot places near you?
they dont do repair work,but will give an honest opinion of any work that needs doing.
