MinorMatt wrote:cam or camshaft? I bet its cam.
Cam position sensor is the timing cam in the pump - and normally means you need to fit another pump (or convert to bosch)
Willem molenaar wrote:MinorMatt wrote:cam or camshaft? I bet its cam.
hello Minormad thanks voor the replay i have cleant up the contacts on the pump and the ecu put inn 0.5l minerale 2 stroke oil and now drove 10 miles and the
ecu licht went out an it seems its ok now is this possible?
