mk4 smiley transit horn not working
Postby cuky » Sat Oct 21, 2023 2:00 pm
Horn has stopped working.
20AMP fuse , which is also indicators fine.
battery tested the horn: it works when tested direct from battery
indicators all work fine.
Does anyone know any thing I can test next. How would I test the switch itself and would recommend where to get replacement.
I have seen then on web for about £20.
Dont want to buy a replacement switch unless I can confirm that is the issue.
All other electrics are fine
cuky
Re: mk4 smiley transit horn not working
Postby gotgcoalman » Sat Oct 21, 2023 2:37 pm
Use a multimeter to test voltage is getting to the horn when stalk is pressed.
If not it's either wiring or stalk.
Toot toot
Sent from my ONEPLUS A6003 using Tapatalk
Too bloody quiet :shock:
gotgcoalman
Postby cuky » Sun Oct 22, 2023 11:04 am
Many thanks for tip. didnt need a new switch.
bad wiring connection was the issue.
multimeter testing to just red/yellow worked fine. so just removed the extra custom wiring bits the previous owners had done , additional wiring adding to red/yellow line. this custom section no current.
As it was once an ambulance, i assume this extra wiring was to hook the horn into the siren relays, which I removed recently. about the time horn stopped working i bet.
sorted! thanks
cuky
Postby gotgcoalman » Sun Oct 22, 2023 12:18 pm
Now you need to join the big horn club
TOOT TOOT
gotgcoalman
