Mk5 2.0L Petrol MT75 Gearbox Noise
Postby Peter Clayton » Thu Nov 16, 2023 11:01 am
3rd query in 2 weeks...previous queries answered. Yey!
Whilst driving as normal, and I come off the accelerator, in 2nd or 3rd gear, there is a humming/whirring noise coming from the gearbox (I'm guessing). If you push the gear stick forward it eases a smidge, but is still there. Trying to describe the noise is something like a "vum vum vum". Once I flip it into neutral it goes. No noise whilst accelerating.
Any ideas greatly appreciated.
Cheers Peter.
Peter Clayton
Re: Mk5 2.0L Petrol MT75 Gearbox Noise
Postby V184 » Thu Nov 16, 2023 12:22 pm
check the rear flange is tight
V184
Postby MinorMatt » Thu Nov 16, 2023 12:39 pm
Have you checked the oil level in the gearbox?
Is it the right oil in the gearbox?
Simple things first :)
Postby Peter Clayton » Thu Nov 16, 2023 3:54 pm
Checked and replaced gearbox oil as recommended in a previous post. The noise was there prior to oil change.
What is the rear flange? Excuse my doofusness
Peter Clayton
Postby MinorMatt » Thu Nov 16, 2023 4:03 pm
Rear flange is where the propshaft mounts
If its loose though, the speedo normally does weird things
Postby Peter Clayton » Thu Nov 16, 2023 4:06 pm
Thanks Mat
I'll check that out
Peter Clayton
Postby V184 » Thu Nov 16, 2023 5:31 pm
MinorMatt wrote:Rear flange is where the propshaft mounts
And can jump out of 2nd gear !
V184
Postby jay » Fri Nov 17, 2023 12:19 pm
post a vid up of the noise is helpful as well..
mk1 connect tourneo
jay
