cherniy_chack wrote:Guys, oil has very little effect on the noise of the engine.
The setting of the high-pressure fuel pump and injectors has a much stronger effect on the noise and thrust of the engine. Even the clearances in the valve mechanism have little effect on engine noise compared to the setting of the pump.
There can be any oil in the engine, as long as it is there.
I am Vitaly “cherny_chak” from Kyiv, Ukraine and I have been familiar with diesel engines since childhood, and I will soon probably turn 70 years old.
