Mk5 IFS into mk3 Independent front suspension
Postby Bruce e » Fri Dec 29, 2023 3:19 am
I am putting mk5 IFS into my mk3 and I am trying to work out the shocks. Are the shocks themselves the same and is the load spreading mounting at the top that is different .The mk3 is 1988 and have found shocks for 1991 to 1999. Mk3 parts are impossible to get in NZ as they were never officially imported by Ford
Sent from my SM-G390Y using Tapatalk
Bruce e
Re: Mk5 IFS into mk3 Independent front suspension
Postby dumper » Fri Dec 29, 2023 6:23 am
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby Keef » Fri Dec 29, 2023 9:41 am
The bottom of the shocks are definitely different but I'm not sure about the tops.
You might be able to use a Mk5 shock with a Mk3 top mount or maybe redrill your van to accept the Mk5 3 bolt top mount?
If your current shocks are ok, you can elongate the bottom mounting holes to fit the Mk5 hub.
I've got a Mk3 that I'm told has Mk5 ifs with Mk5 shocks but I have only just got it and haven't looked to see how they've done it yet.
I believe the front subframe horns are slightly different but that might just be hole sizes?
I'll be interested to see how you get on with this.
Keef
Postby dumper » Fri Dec 29, 2023 12:20 pm
When I had my mk3 it had a Ford recall for the front suspension top mounting they drilled holes in the two panels that the shocker went into and bolted them together with 3or 4 6mil bolts probably on the later models they used more spot welds to hold them together
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby Bruce e » Sun Dec 31, 2023 5:24 am
Thanks guys, have a good downer IFS with bigger springs brakes and 6 stud 15 inch wheels
Bruce e
Postby MinorMatt » Tue Jan 02, 2024 1:39 pm
As you have spitted, the top of the dampers are different.
The hole spacing where it mounts to the hub is different too - but that can be "adjusted" with a round file
Lucas Laser 2000 & IDS
95 N Hallmark (white)
96 P 150 TD 100PS LWB Hi-Top
96 P Autosleeper Duetto
2 x 2006 Mk7s
