mk3 cabin transit diferencial, same as normal mk2 diferencia
Postby trashpanda » Mon Feb 19, 2024 2:52 pm
dead everyone.
I have a whinny rear dif on my mk3, and i have a mk2 that was destroyed in a fire, but i'm guessing the read dif is still fine, the mk2 is a high roof but doesn't have double wheels on the read, the mk3 is a cabin with double rear wheels.
Would i be able to fix my diff using the mk2 diff?
kind regards
1997 MK5 Chassis Cab 2.5Di
trashpanda
Re: mk3 cabin transit diferencial, same as normal mk2 difere
Postby dumper » Mon Feb 19, 2024 7:43 pm
They will be different the twin wheel will be 6 stud wheels and the single wheel will most likely be 5 studs there was some 6 stud single wheel but I think from memory that they were narrower then the twin wheel axel if you can put some photos up it will give a better idea of what you have
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby trashpanda » Mon Feb 19, 2024 8:08 pm
can i use the internals? and skip the complete axle ?
i just noticed i said mk3 and mk2 i meant the mk5 and mk4
trashpanda
Postby twin wheel camper » Mon Feb 19, 2024 8:47 pm
trashpanda wrote:can i use the internals? and skip the complete axle ?
If your van and the donor have the same number of wheel nuts (either 5 or 6 stud) they will be interchangeable but if not the internals definitely won’t swap over.
twin wheel camper
