Seatbelts slow to retract
Postby AMYH95 » Mon Feb 26, 2024 6:59 pm
Hello everyone, I need some help please, both the driver and passenger side seatbelts will not retract quickly enough or fully, which I believe is an MOT failure. I have washed and polished the belts and guides, but this has not helped. I removed the plastic trim to look at the reels, but they are behind the metal of the van itself. My questions are is it easy to remove and replace the reels and can you do anything to speed up the recoil if you do.
AMYH95
Re: Seatbelts slow to retract
Postby baba2000 » Tue Feb 27, 2024 9:43 am
Hi have you tried some wd40. The smell will evaporate. There is a product called FIXT400. It applies a tough moisture resistant PTFE lubricant, It's a high performance multipurpose maintenance spray with outstanding penetrating lubricant. Like WD40 but with out the smell. You need to spray it in the centre where the real spins.
baba2000
Postby AMYH95 » Fri Mar 01, 2024 9:26 am
Hi thanks for your reply I haven't had time to try due to family illness but will get back to you if it works, many thanks again.
AMYH95
