evening all
got an issue with my old transit, i went out on a short journey everything was going fine until i hit main road and it started to struggle abit getting to 50mph, got off the main road and the revs and idle went abit funny a phew time times then it started stalling whilst in neutral and having to slow down ?
i got back just about.. left it for an hour wouldn't start unless you had throttle down it idled fine but gave it any high revs it would just stall out, it done that once or twice then refused to start altogether.
noticed a leak off the line to lift pump from the tank, thought this would be the ideal time to install all the new parts so took its face off and done the timing belt installed all new fuel lines fuel filter and electric lift pump new stop solenoid primed the filter and pumps got fuel to the injectors and its just cranking. was out there all day and its just cranking, i got it to fire on easy start but it didn't continue (only had a tiny bit in can left to fire it) so gave it a tow and after about 5/6 attempts it fired a couple of times eventually to a point where it ran for about 30 seconds revved up okay then died after i gave it a rev again ???
was out there all today triple checking everything, done a compression test and that came back good, everything seems to be spot on i just cant get it to fire under its own doing...
im by myself tomorrow so cant grab a tow or get someone to crank it to give the injectors ago again, got no Manuel hand primer either .. was thinking of grabbing a tin of easy start in the morning but didn't want to over do it with the stuff would rather get it running off its own steam any suggestions with what i should try or what the problem could be ?
