Front brake discs 6 bolts part code mk3
Postby Kriss1990 » Thu Mar 21, 2024 9:01 am
Hello, I need the part code or the store where I can buy 6-bolt front brake discs. Thanks for help
Kriss1990
Re: Front brake discs 6 bolts part code mk3
Postby Chug » Thu Mar 21, 2024 9:44 am
The discs are five bolt for single and twin wheels
https://www.catcar.info/ford/?lang=en&l ... UwMw%3D%3D
Chug
Postby Kriss1990 » Thu Mar 21, 2024 10:45 am
5 hole discs fit normally? Do I have to remove the hub and bearing to replace it?
Kriss1990
Postby Chug » Thu Mar 21, 2024 11:08 pm
Yes all models have 5 bolt hole discs, just the diameter is different and yes you have to remove the bearing/hub, so a good time to get new bearings whilst you're at it.
Chug
Users browsing this forum: Altransit
