Chassis Cab LWB Prop Shaft
Postby Motorhome-Les » Mon Apr 01, 2024 9:08 pm
Hi all,
I have a LWB 1992 chassis cab, with approx 80,000miles, onto which a motorhome was fitted when new.
The propshaft has two rubber doughnut style auxiliary mounts (roughly at 1/3 and 2/3 distance between the gearbox output flange and the rear axle input flange) along the length of the propshaft, which are bracketed to the chassis of the vehicle. there is currently a small amount of side to side movement of the propshaft when I grasp the propshaft and push it sideways, on both of these mounts. The propshaft remains central in the two mounts, when I release it.
Does anyone know if this movement is expected, or should these mounts hold the propshaft bearings more firmly in place - I'm currently experiencing slight engine judder, when maneuvering at slow speed and slipping the clutch.
I don't want to replace these unless they are identified as worn.
Hope you can help.
Best regards, Les
Motorhome-Les
Re: Chassis Cab LWB Prop Shaft
Postby Chug » Mon Apr 01, 2024 9:52 pm
yes you will get a little movement in the rubber if you pull/push on the propshaft but it shouldn't move much, as long as the rubber isn't split then they are usually ok, could be the bearings though, I get it up on sturdy axle stands and get someone to 'work the clutch' whilst I have a listen nearer to the prop and wheels.
Chug
Postby V184 » Tue Apr 02, 2024 1:34 pm
notorious for clutch judder especially if fitted with pattern clutch, centre bearing rubbers also known to wear :wink:
V184
