From a CAV pump to a Bosh
Postby estellef » Tue May 14, 2024 5:32 pm
Hello,
I have a transit 2.5d mk3 from 1990.
No turbo, no electronic.
My CAV pump is leaking and broken.
Can you please tell me what equipment I need to do a swap to a Bosh Pump.
- Tubes ?
- New injectors ? ( Can I keep the old ones ?)
I have found somebody who has everything !
I have used the search engine, but any additional answer would help me.
this is this one .
On my lucas, the 'injectors returns" tube is doubled, while I can't see that on this.
LUCAS :
star creator code
How will I do ? The rest seems to be ok.
BOSH :
estellef
Re: From a CAV pump to a Bosh
Postby V184 » Tue May 14, 2024 9:57 pm
Injectors are different for Bosch pump
V184
Postby Bruce e » Tue May 14, 2024 11:07 pm
You may need the crankshaft and camshaft pulleys as the belt profile is different. One of my mk3 has the same injectors as my mk5 the other has the older bigger two bolt tractor stile
Sent from my SM-G390Y using Tapatalk
Bruce e
Postby V184 » Wed May 15, 2024 4:17 pm
Bruce e wrote:You may need the crankshaft and camshaft pulleys as the belt profile is different. One of my mk3 has the same injectors as my mk5 the other has the older bigger two bolt tractor stile
Injectors same fitting, different internal pressures etc :wink: pulleys should be ok ?
V184
Postby estellef » Fri May 17, 2024 2:46 pm
Thank you, what do you mean about Two bolt tractor style please, is it Bosh compatible , thanks .
I will post a pic
estellef
Postby dumper » Fri May 17, 2024 3:19 pm
On my G reg mk3 190 with a Bosch pump I did the opposite change to a cav pump as we had a new reconditioned pump at work going in the scrap bin the only thing I can remember is having to play around with the injection pipes talking to the shop that reconditioned the pump they said remove the clamps and fit each pipe independently then makeup new clamps as it was a long time ago I don’t remember any problems it pinned up as normal and I ran it with the Bosch injector's it was still running 3 years later when I sold it so it must be possible to do the opposite
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby Bruce e » Fri May 17, 2024 8:51 pm
I have two mk3s they have the same old style cav rotary pump but one has the same stanadyne pencil injectors as my mk5s with a single retaining bolt the other one has cav style injectors with two mounting bolts similar to my York 2.4 motor and most of the tractor's I work on.
Bruce e
Postby V184 » Sat May 18, 2024 3:30 pm
Bruce e wrote:I have two mk3s they have the same old style cav rotary pump but one has the same stanadyne pencil injectors as my mk5s with a single retaining bolt the other one has cav style injectors with two mounting bolts similar to my York 2.4 motor and most of the tractor's I work on.
The injectors changed to stanadyne around 88 F reg along with the mt75 gearbox, the early turbos (very rare) continued with the two mounting injectors
V184
Postby estellef » Tue May 21, 2024 8:42 pm
Hello,
I just received the BOSH pump, the injection pipes, the support.
The end of my accelerator cable doesn't fit on the pump ball, I guess it's because it's the old 1990 model?
The pulley looks exactly the same and the timing the same.
What bothers me is the diesel outlet and inlet tubes which are not the same size, he sent me the original ones but one is cut, otherwise the filter support is the same, one Lucas.
From what I understand, I am blocked by the accelerator cable which does not fit into the pump ball and the 2 inlet-outlet tubes.
With the lucas, the fuel outlet was in the tank, and it looks like the fuel outlet is in the fuel filter with the bosh pump, I don't know if that will be a problem.
Another problem, I can't turn the bosh pump by hand. I read elsewhere that they are hard unlike the Lucas, but I wouldn't want to break the engine.
My bosh pump number is 0 460 414 142 VE4
I don't know at all if it could have seized and I don't know if it's normal, I don't dare to force it by hand.
On the other hand, it fits perfectly into the support, and I was surprised that the pulley was adjusted the same as the lucas, the hole is in the same place.
The fuel filter holder he gave me has fuel pipes stuck in it, I don't understand.
Any help appreciated.
I also have a very stupid question, I can't understand if the diesel inlet is at the front or at the back of the bosh pump....
estellef
Postby estellef » Tue May 21, 2024 10:11 pm
Ok, I think I have tried to plug the accelerator cable at the wrong place, it was below
estellef
Postby estellef » Wed May 22, 2024 10:15 am
Edition :
I have found a complete Lucas CAV to BOSH swap Ford Transit tutorial there :
https://www.ford-transit-forum.com/t767 ... moteur-25l
but it's in French and you have to be registered, There are pics and all of that, you can translate.
estellef
Postby estellef » Wed May 22, 2024 11:05 am
Hello Bruce ,
I still have the old injectors tractor type with the returns from 1990, the hose was fixed at the top of the lucas pump, on the front, on a pilone. ,
can I plug theses return at the back of the Bosh Pump, please ?
I can buy a longer hose and plug it there ?.
Please don't tell me I have to buy 4 news injectors with no returns, oh nooo.
People seem to say that the old tractors double injectors were compatible, is it true ?
Thanks a lot !
If somebody needs the french tuto I can maybe save it
estellef
Postby estellef » Tue Aug 13, 2024 3:14 pm
Hello,
Finally , my swap from Lucas CAV to a BOSH VE is a success ... :D :D :D :mrgreen:
This is my post in French ( for pics) :
https://forum-auto.caradisiac.com/topic ... /#comments
It's a party, because the truck finally restarted with the BOSH VE type pump, I didn't believe it anymore, but it restarted straight away!
So, in order I first reassembled yet another Lucas CAV pump, which started to restart very well every time,
this one consisted of a front part found at the right place at a discount on an H.S pump and the original hydraulic module, of which I had unseized the 4 pistons.
On the other hand, curse, the pump remained fully accelerated, all the time, nothing to do, she didn't want to know anything. However, it seems to me that I have reassembled the part of the acceleration arm correctly, I don't know if it's that or the front part which is causing this. So I had changed all the seals, it was no longer leaking, but accelerates fully, I don't know why, but starts flawlessly.
So, I said to myself "Okay, I've had enough, I'll try the BOSH VE injection pump" which I found cheaply on LBC.
So, in the meantime, I'm rebuilding another Peugeot Boxer truck from 2003, because I thought the transit wasn't going to start again.
Then, I bought AGAIN another rather expensive BOSH VE pump, rebuilt by BOSH Germany, but not too expensive anyway (around four hundred), because I had sworn to myself never to abandon this truck.
Then, 1 month later, I fitted the first BOSH VE pump for 160 euros that I found, no longer believing in it at all, I had to tighten the timing belt a little by pushing the tensioner roller, because the pulley is not quite the same on the BOSH, it has 4 holes, but the same number of teeth. Note that I used more than 100 Rylsans collars in total, to block the timing belt each time, so as not to lose the adjustment and I carried out perhaps 12 or 15 reassembly-disassembly of the injection pump LUCAS CAV, all in all, an exhausting thing, whereas with the BOSH, it would have started again straight away...
Note that I bought mecarun and injected it with a little diesel into the BOSH P.I using a bulb and waited for a month, if so, it played a role in the success .
After doing my research on the Ford Transit forum in English, I understood that the BOSH engineers must have created this pump for this engine, and that it was compatible whether it was the LUCAS CAV, and the BOSH VE Pump, except that the teeth of the PI pulley are something like 0.3 mm instead of 0.25 mm. We see in the following photo that the teeth of the belt do not go "all the way".
Then, my fear was that the BOSH VE pump was very hard to turn by hand, normal because it is not at all the same system as the Lucas pump, there are big springs inside it seems.
but I was afraid that it would break the belt, or fatigue the starter, well no, the D-day arrived, an hour ago and it started in 2 seconds, after carrying out the bleeding procedure on the 4 injectors ( Start loose injectors, then retighten)
The important thing for transit owners is not to confuse the LUCAS CAV pump from 1990 and the electronic LUCAS EPIC pump which, it seems, was not too good, I had a LUCAS CAV, which seems to be reliable, but can leak and in these cases, it's annoying. As I was a bit nag at the beginning, I tightened too hard without taking into account the torque and I damaged the original pump, whereas I could have started again by being more careful, just by changing the seals.
Well, I haven't driven it yet but the VE pump already has a better idle than the other, and makes a nice noise, it's a party, I'm on cloud nine!
For the hoses that weren't long enough, I just bought some and it fit into the usual rigid hoses with a rylsan. You also need BOSH tubing instead of LUCAS.
I had bought an electric pump on ALI, just in case, but there was no need, it started, and it accelerates!!
My question is that I hope that the belt which has smaller teeth will not jump, because they say that you also have to change the other pulleys so that they are all in 0.3mm, but will find a pulley like that in 2024!
So either, you have to strain galore, but I don't dare, or I leave it like that and try to ride...
So, I find myself with a VE pump reconstituted by Bosh Germany and 3 Lucas CAV pumps which are not working well to resell...
Thanks again to the good person from the South of France who sent me the whole package, VE pump, Bosh and Pulley tubing, without that, it was ruined!
I think the Lucas CAV is a great piece of material, and starts really really nice, but I was a rookie and did not do things well to fix seals.
We can see that the Lucas pump started well because even when turning by hand, a jet comes out through the 4 outlets, step by step and it is noticeable. I have been able to acquire a lot of know-how and delicacy in handling the injection pump since these 4 months of breakdown. I now constantly work with vinyl gloves and change them constantly (Packs of 100).
estellef
