by MinorMatt » Tue Jun 04, 2024 1:30 pm
I will guess you don't then....
Have a look in the engine bay. There is a fuse box attached to the inner wing on the drivers side below the battery.
In there is a half sized brown relay. if you link the 2 big terminals it should start and run (as a diagnostic only). If it fixes the problem - replace the relay
