Hello Transit driver,
We drive a MK4 (Ford Nugget, '96, 2.5 TD, 63 kW).
My other problem: The left turn signal no longer works. And I'm absolutely clueless:
• When the hazard lights are activated, all the lights work - including all the lights on the left side, which are not currently lit when the left turn signal is activated.
• When the hazard lights are activated, all the turn signals light up, including the left ones. However, strangely enough, the symbol in the cockpit is also flashing, which should only light up if I had a trailer or a bike rack with lights connected to the light circuit, which is not the case. The plug on the trailer hitch appears to be clean and intact.
• The turn signal relay in the fuse box at the front near the driver is faultless. Even a new turn signal relay didn't help:
o when you turn right, the relay clicks acoustically at a normal frequency and all the turn signals on the right light up.
o When the hazard lights are on, the relay clicks acoustically at a normal frequency and all indicators (including the left ones) light up.
o When you turn left, the relay clicks acoustically at too fast a frequency and the left lights do not flash.
• I visually checked all the installed fuses: the fuse elements are intact.
Does anyone have any idea what the cause could be?
Thank you in advance for your help, Carsten
P.S. If my English is slightly awkward, sorry for that. I`m not mother tongue.
