Keef wrote:It's not that uncommon.
If the unsecured sprocket has worn the woodruff keyway in the camshaft then you'll probably need a replacement camshaft which is an engine out job.
You need to take the sprocket off to check for damage.
Sounds like you might be lucky though and if you are, just replace any missing or damaged parts, double check the timing and job done.
James H wrote:I was away for a while so didn't get a chance to look at the van. It turns out that I wasn't lucky and it has mashed up the end of the camshaft where the woodruff key sits. @V184 how have you seen the sprocket bodged back on when the key has gone/damaged
V184 wrote:James H wrote:I was away for a while so didn't get a chance to look at the van. It turns out that I wasn't lucky and it has mashed up the end of the camshaft where the woodruff key sits. @V184 how have you seen the sprocket bodged back on when the key has gone/damaged
from memory loads of metal weld and make sure the sprocket is aligned correctly & new bolt
