Advice Need Group
Advice Need Group
Postby VG1997 » Sun Oct 27, 2024 5:20 pm
OK Timming belt slipped on Crankshaft.
Caused by fan Belt getting rapped in between the crank pulley.
OK I remove broken fan Belt .set Timming
Back up . Pin Crankshaft pump & camshaft.
Ohhh buy way this is a 2.5 turbo diesel van.
But now it missing bad.
Question is . Is it just bend push rods .
Would values have hit pistons???
Anyone with knowledge on these engines.
Be much appreciated
VG1997
Re: Advice Need Group
Postby dumper » Sun Oct 27, 2024 8:35 pm
The valves do hit the piston but they usually bend push rods the most I’ve had is 3 and one snapped a rocker arm that’s the most damage I’ve had never had to take a head off , remove the rocker cover and have a look some on here have straightened the push rods with no problems after.
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby VG1997 » Mon Oct 28, 2024 5:30 am
OK thank for your Advice & knowledge.
I will remove rocket cover. In next few days & inspect.
Of what damage I've done . I'll also reply of what's happened too.
VG1997
Postby gotgcoalman » Tue Oct 29, 2024 6:52 pm
Worst one I've had over the years was 5 bent push rods and 2 bust rockers.
I've got a spare set of push rods and some spare rockers "just incase"
Sent from my LE2101 using Tapatalk
Too bloody quiet :shock:
gotgcoalman
