meerkatmag wrote:My van handles like a boat due to the large motorhome body. I've been thinking about fitting anti roll bars to help with this. As far as I know this model (1988 mk3 transit 190) never came with them.
Anyone done this? Is it possible to retrofit and if so will mk6 anti roll bars be the right size?
Cheers
Bruce e wrote:I have gone from a mk3 single wheel motorhome to a dual wheel mk5 190 and the mk5 handles very well even though the suspension is stuffed. You may need to update your springs all round as being 90% loaded 100% of the time ruins them
Sent from my SM-A156E using Tapatalk
Ralph.9 wrote:I have fitted Monroe Air assist shocks to mine, I just increase the pressure to control body roll & no modifcations are needed as they just replace the existing shocks.
V184 wrote:meerkatmag wrote:My van handles like a boat due to the large motorhome body. I've been thinking about fitting anti roll bars to help with this. As far as I know this model (1988 mk3 transit 190) never came with them.
Cheers
easier to fit helper springs (an additional leaf )
Mislaid wrote:https://www.fordopedia.org/parts-catalog/transit-mk3
You will find the parts diagram for the arb's here.
My 100L definitely has a front, can't remember if one on rear.....
meerkatmag wrote:V184 wrote:meerkatmag wrote:My van handles like a boat due to the large motorhome body. I've been thinking about fitting anti roll bars to help with this. As far as I know this model (1988 mk3 transit 190) never came with them.
Cheers
I do have custom leafs at the front with 3x leafs. It's not the support that's the issue it's the roll. It's about as stiff as I could take with 3 leafs so I'm thinking the antiroll bar is the solution wouldn't you say? I think my van has way higher center of gravity than most transits
meerkatmag wrote:Mislaid wrote:https://www.fordopedia.org/parts-catalog/transit-mk3
I can see the parts on those plans but can't find them anywhere on the Internet. Does anyone have these in stock or is there anything similar size/shape from a modern vehicle than can be made to fit? I think that's what I'm hoping for.
