Bleeding fuel problems
Postby Transitpascall » Thu Jan 16, 2025 11:32 pm
I have a MK4 2.5td with an epic pump, I've replaced the fuel filter and lift pump but can't seem to get fuel to the injectors which I have cracked off. Are there any other bleed points or are there any tricks to getting the fuel up?
Transitpascall
Re: Bleeding fuel problems
Postby V184 » Fri Jan 17, 2025 2:56 pm
are you getting fuel to the filter ?
V184
Postby MinorMatt » Tue Jan 21, 2025 12:23 pm
I was asked exactly this, at the same time, through FB.
Fuel filter was replaced dry. Filling and refitting allowed the pump to bleed up
