Spigot bearing which one?
Postby Paulytransit » Sun Feb 02, 2025 7:50 am
I need to change the spigot bearing on my 2.5td mk5. Reading up there are 2 different bearings. Is there a way to confirm which one I have without pulling the box? I'm in Morocco so parts take a while.
Cheers Paul
Paulytransit
Re: Spigot bearing which one?
Postby Chug » Sun Feb 02, 2025 11:49 pm
There's only one for the MT75 part number 1072135 gearbox input shaft bearing,
but if you have a good bearing stockist nearby then its a 6202 2RSH
Chug
Postby MinorMatt » Mon Feb 03, 2025 12:52 pm
As Chug says there is only 1.
6202-2RS. C3 clearance would be ideal
Postby savi18 » Mon Apr 14, 2025 1:50 am
Paulytransit wrote:I need to change the spigot bearing on my 2.5td mk5. Reading up there are 2 different bearings. Is there a way to confirm which one I have without pulling the box? I'm in Morocco so parts take a while.
Cheers Paul
What issue are you having to have the spigot bearing changed.
savi18
Postby V184 » Tue Apr 15, 2025 5:15 pm
Cheers Paul
Common for them to seize up & damage the 1st motion shaft
V184
