Help engine replacement
Postby Slow » Fri Feb 21, 2025 1:09 pm
Hi everyone
I've got a 1992 190 2.5 Di naner engine Luton that we have lived in working on farms up and down the country for the last 13 years or so . Been great reliable van.
But... .. it's getting to slow now think the rings are going .
So I would like to put another engine in either a 2.0 petrol or another d.i with turbo or any other different engine that's bin done with out messing about to much .
Also if anyone now's of a place or person I can take it to and buy the engine+ fitted
If I can just hold 55 mph on those long hills I will be the happiest man in England.
We are in the Sussex Hampshire Kent area at the mo.
Any suggestions will be greatly appreciated
Kind regards gaz
Slow
Re: Help engine replacement
Postby Slow » Sat Feb 22, 2025 10:45 am
Also does anyone know if the 4eb 4ea 4ea,eab engines would go straight in
Regards
Slow
Postby Chug » Sat Feb 22, 2025 11:03 am
All the 2.5di engnes are basically the same just have different ancillary parts, so you may have to swap all your bits on to any donor engine.
Chug
Postby MinorMatt » Tue Feb 25, 2025 11:55 am
Slow wrote:Hi everyone
Kind regards gaz
Have a chat with "Neil Clark" the Transit Mk5 Smiley group admin on facebook. I'm fairly sure he will have a good engine and will fit it?
Lucas Laser 2000 & IDS
95 N Hallmark (white)
96 P 150 TD 100PS LWB Hi-Top
96 P Autosleeper Duetto
2 x 2006 Mk7s
Postby Slow » Tue Mar 11, 2025 10:21 am
Thanks minormat will contact him
Regards
Slow
Postby ColinJack » Tue Mar 11, 2025 10:53 am
We replaced our 2.5 di in our 1989 Mk3 with a turbo engine from a 2000 Mk5.
Straight swap and goes like a rocket.
I also turned the boost up to 15psi and fitted an intercooler. :wink:
You will be gobsmacked with the performance!
1989 Mk3 Reimo Camper
1980 Mk2 Holdsworth Camper
ColinJack
Postby Slow » Fri Mar 14, 2025 9:23 am
Hi all I've looked up Neil Clark transit mk 5 smiley on Facebook and came up with Neil young ,he made some good music back in the day but he doesn't have a transit engine.anyone got an idea how to contact Neil Clark.
Many thanks and kind regards
Slow
Postby Chug » Fri Mar 14, 2025 9:52 am
Chug
Postby zephyr » Sat Mar 15, 2025 1:04 pm
This is the Mk5 facebook group you're after:
https://www.facebook.com/groups/mk5.smiley.group.npc
Transit...... The first and best MPV
zephyr
Postby Slow » Mon Mar 17, 2025 8:41 am
Thanks guys
I've been offered what looks to me a Lucas epic turbo engine will my Bosch pump and ancillarys go straight on and the turbo still work . I see that there is a vacuum that operates the turbo with a wire on it would the wire just be junk
Regards
Slow
Postby Slow » Mon Mar 17, 2025 9:07 am
Also the engine is from a 1992 van so I think I read on hear that the turbo epic engines were 100 horse power does anyone no if this is correct
Slow
Postby MinorMatt » Mon Mar 17, 2025 9:53 am
Slow wrote:Thanks guys
Regards
Yes you can fit the Bosch pump, but you will need to advance the timing and increase the fuelling.
Turbo is not vacuum operated - its just got a conventional wastegate
2 x 2006 Mk7s
Postby Slow » Sun Mar 23, 2025 8:56 am
Hi everyone
Does anyone have an air box for sale or know we're ican get one from for a 1992 turbo engine
Regards
Slow
Postby Slow » Mon Apr 28, 2025 2:43 pm
Thanks for helping everyone, would like to put photos up but can't figure it out.
Slow
Postby Slow » Mon Jun 02, 2025 6:53 pm
Thanks to everyone that helped with the engine replacement and the Lucas to Bosch change. Didn't have to advance the timing and haven't uped the pump yet and goes like a farari.
I'm putting my old engine ( 4da banana) on eBay 99 p start
Regards
Slow
