Transit 1998, 2,5 TD, high-pressure pump 8720B050A
Postby jt2007 » Thu Apr 03, 2025 7:01 am
Hello everyone
I'm hoping for some collective wisdom.
The above Transit needs a solution for its high-pressure pump:
Pump type 8720B050A
S# 05745FRG
Lucas EPIC DSA1190
Problems:
Cam ring has chips
Case pressure valve defective
1. Repair the old pump
2. Purchase a new/used pump
3. Replace the pump with a mechanical pump (supposedly available)
Can anyone help me?
Thank you very much.
jt2007
Re: Transit 1998, 2,5 TD, high-pressure pump 8720B050A
Postby Chug » Thu Apr 03, 2025 1:26 pm
I think you will be lucky if you can find somewhere that repairs the pump, I very much doubt you will find a new one, and a used one is a gamble, so maybe a Bosch VE mechanical pump would be best.
Chug
Postby MinorMatt » Fri Apr 04, 2025 10:13 am
Do you have a manual or automatic gearbox?
Postby Bruce e » Sun Apr 06, 2025 11:53 pm
I have 2 good reconditioned pumps in NZ
Sent from my SM-A156E using Tapatalk
Bruce e
Postby Gmguy » Sat Sep 27, 2025 10:11 am
Hi Bruce e,
How can i get in touch with you about an epic pump?
Gmguy
Postby Gmguy » Sat Sep 27, 2025 9:34 pm
Bruce e wrote:I have 2 good reconditioned pumps in NZ
Hi Bruce e, how do I get in touch with you about a epic pump? Am in nz also
Gmguy
Postby Chug » Mon Sep 29, 2025 10:25 pm
Send him a Private message from his profile here memberlist.php?mode=viewprofile&u=104381
Chug
Postby MinorMatt » Tue Sep 30, 2025 9:11 am
DSA1096, DSA1190 and DSA1191 are interchangeable. Any others arnt
DSA947 is mk4 only
DSA1284 is 115PS TDI only
