My year 2000 MkV 2.5TD 5 SP manual Box Camper Van here in Sunny NZ finally gave up the ghost , going into limp mode throwing errors etc, and finally not running.
So bit the bullet a few weeks back and ordered a refurbed Bosch VE 460 series pump from Merlin Diesel Systems in UK. Looks like new !!
Few Issues though :
1/ The new pump doesn't have a rear support bracket, and am worried about hanging it all of the front plate. The Epic support bracket wont work with this pump. Not sure where to get a bracket that works with this pump other than maybe getting one custom made? May test run for a few mins with no rear bracket.
2/Have quickly mounted the new pump. To test it works ok. ITs a B'std getting the 12v Solenoid wire on when its mounted. Why didn't I put this on when it was on the bench.!! Already dropped the nut down the back of the motor.
3/ Timing wise it was all pinned up, and the refurbed pump was pinned TDC?, So have gone with this, and will adjust it roughly using the front bolts. Am planning on trying to start it up, but with no Radiator or coolant in . eg only the cam belt. Should be ok as long as its not more than a minute or so of running?
4/Plumbing Wise I've found a few pics on here and have done something similar. Cut of plastic hard pipes and routed , but not sure if have them the right way round? I guess If I pull of the pipe to the filter and crank I can figure out which is the flow and which is the return line to the filter. Does the fuel supply line go to port nearest to the pulley (front of engine)
5/ Any tips on getting all of the air out of a new pump and lines with no fuel in them. Other than just keep cranking the motor over.
