Since fitting a turbo to my early na di I've got a light oilly seep from the head gasket on the intake side of the engine around cylinder 3. I think what's happening is at full boost (10psi) the cylinder pressure is too high and I get some cylinder gasses escaping to outside. Also had high blowby at full boost but this has been solved with enlarged pcv hoses.
I didn't think 10psi was too much for these na pistons and cams? I was wondering if I should check the head bolts are tight around cylinder 3. Good or bad idea?
Any advice appreciated.
