gearbox removed
gearbox removed
Postby FDN850HU » Sun Apr 27, 2025 7:39 am
Hi, my mt75 gearbox will be soon removed so as to change shaft seal and clutch, just wanted to ask whether it was a good opportunity to do something around the gearbox. Is there anything i can do with it apart from cleaning? thanks a lot.
FDN850HU
Re: gearbox removed
Postby dumper » Sun Apr 27, 2025 10:52 am
Never had the problem myself but the clutch arm is known to bend I have had the pin that it pivots on wear ,you said you have a seal to change I only changed seals if leaking inspect the spigot bearing and change if necessary in the past I’ve had to get the flywheel face skimmed if it’s had clutch judder and the odd ring gear .
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Re: gearbox removed
Postby FDN850HU » Sun Apr 27, 2025 2:39 pm
Thanks mate gonna check clutch arm and pivot point. Spigot bearing will be changed we thought about that. Flywheel: gonna check it thanks! We ve got everything covered in oil underneath, so we do think it must be the main seal and its housing seal, we do that two for sure. Was thinking about the gearbox where the shifting rod attached to, there could be something to be done? Will see it thx again.
FDN850HU
Re: gearbox removed
Postby dumper » Sun Apr 27, 2025 4:08 pm
If I remember correctly there’s a 3 bolt plate for removing the camshaft had them leaking before and sometimes it’s not been a leak in the belhousing but coming from the rocker box gasket leaking into the bellhousing
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Re: gearbox removed
Postby V184 » Sun Apr 27, 2025 6:12 pm
shaft seal ?
V184
Re: gearbox removed
Postby dumper » Sun Apr 27, 2025 6:30 pm
I took it he ment crankshaft or gearbox input shaft seal.
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Re: gearbox removed
Postby FDN850HU » Wed Apr 30, 2025 4:28 am
It will be the rear main oil seal behind the flywheel, but i meant the top part of the gearbox where some kind of seal could be replaced? Where the gear shifter stick is attached to. I am not yet familiar with the gearbox but im gonna show if removed. Thx
FDN850HU
Re: gearbox removed
Postby FDN850HU » Wed May 21, 2025 8:15 pm
some update, gearbox is cleaned and installed, although there is a rubber gaiter / dusc cap on the top of the gearbox (still reachable from the cabin), it is pretty worn and somewhat damaged. Is there a source for such or only 2nd hand? tia
FDN850HU
Re: gearbox removed
Postby Peterr » Thu Oct 09, 2025 1:18 pm
I have a spare MT75 gearbox I salvaged. Turning by hand turns the spigot but I’m unable to move the gear selector to different gears, seems stuck in first. I suppose If it were in neutral the spigot wouldn’t turn. I wanted to make sure it was in good condition before selling it. Any way to test it ?
Keep on Transiting !
Peterr
Re: gearbox removed
Postby Peterr » Fri Oct 10, 2025 7:41 am
Ok, figured it out. Opened gear shift port, used a large screwdriver to slide into alignment the 1st/2nd selector. Apparently it had either popped out or it was improperly reassembled. Now I can select all gears and return to neutral (spigot no longer turns when manually turning shaft)
Peterr
Re: gearbox removed
Postby Peterr » Fri Oct 10, 2025 12:54 pm
Just wanted to confirm gearbox model:
Peterr
Re: gearbox removed
Postby Peterr » Wed Nov 05, 2025 8:10 am
Could someone please confirm if the above gearbox is a MT75?
Peterr
Re: gearbox removed
Postby gotgcoalman » Wed Nov 05, 2025 9:14 am
Looks like an mt75
Sent from my LE2101 using Tapatalk
Too bloody quiet :shock:
gotgcoalman
Re: gearbox removed
Postby V184 » Thu Nov 06, 2025 4:33 pm
Just make sure with it in neutral the rear flange/front 1st motion shaft turn freely :wink:
V184
Re: gearbox removed
Postby gotgcoalman » Mon Nov 10, 2025 11:40 pm
V184 wrote:Just make sure with it in neutral the rear flange/front 1st motion shaft turn freely :wink:
He's done the "green bag quick shift mod"
gotgcoalman
