2.5di Gearboxes
2.5di Gearboxes
Postby Mislaid » Mon Apr 28, 2025 10:31 pm
Looking into an automatic conversion onto the back of a Di.
I know the standard Transit auto box is the A4LD beastie, but are there any other straightforward fits out there?
Just trying to increase the options on availabilty
TIA
Mislaid
Re: 2.5di Gearboxes
Postby MinorMatt » Thu May 01, 2025 11:14 am
No, except the C3 from a pre 1988 2.5Di
But unless you want to fit the lucas EPIC system, you want a pre 1994 A4LD. I think there is one on ebay at the moment?
Re: 2.5di Gearboxes
Postby MinorMatt » Thu May 01, 2025 11:16 am
Re: 2.5di Gearboxes
Postby Mislaid » Thu May 01, 2025 1:30 pm
Thanks Matt
Guessed Tranny auto boxes would be rather thin on the ground, didn't realise was same one in other fords.
i'm imagining still not a common box.
Looking into viability of a disabled use camper arrangement, obvious first step being the changing of gears.
Had considered heresy, like dropping in a Merc OM602 and matching box, as much easier for me to get hold of.
Will look up the flebay one
Cheers
Mislaid
Re: 2.5di Gearboxes
Postby MinorMatt » Thu May 01, 2025 1:40 pm
Transit bods arn't bothered what engines you fit
BMW M47(?) seem quite popular at the moment. The auto gearbox on those actually bolts up to the propshaft (if you drill an extra hole)
