Which tool for lowering the spare wheel?
Postby Kiwi MAN » Wed May 07, 2025 11:15 am
Hi everyone,
Our 1996 MK5 LWB van did not come with an original jack or wheel brace and I need to get the spare wheel lowered. From this forum I've discovered that there are two possible connections for the 'winch' - a 'female square' and a 'male octagon'. I'm trying to work out which tool I need to get, but when I peer down the hole in the bumper, this is what I see:
I'm not seeing a square or an octagon??
Am I looking at the wrong thing, is there something missing or...
Thanks for any help.
Mark, Wellington, NZ.
Kiwi MAN
Re: Which tool for lowering the spare wheel?
Postby Altransit » Thu May 08, 2025 12:48 pm
Mine was a tapered, male square on the end of the jack winder thingy.
It goes in horizontally to a slot into the bodywork on the rear panel, just above the bumper. You need to push in, when winding, to keep it engaged :)
Postby Altransit » Thu May 08, 2025 12:51 pm
Altransit wrote:Mine was a tapered, male square
Maybe it was an octagon, but definitely male (long time since I had a Mk5 :oops: )
Postby dumper » Thu May 08, 2025 2:29 pm
Mine had a octagon it was tapered so when in the Jack you could turn it at a upward angle
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby Altransit » Thu May 08, 2025 4:03 pm
Maybe it was an octagon, it was a while ago now :oops: :lol:
All I remember was that it didn't fully "engage" in mine, and you had to keep it pushed in hard as you turned it :mrgreen:
Postby Kiwi MAN » Fri May 09, 2025 10:38 am
Thanks for your replies. I'll try and find something square / octagonal and give it a go.
Local breakers don't have an original handle.
Cheers,
Mark.
Kiwi MAN
Postby Chug » Fri May 09, 2025 1:39 pm
Is the yellow bit some sort of cover over the octagon/square winder bit? And I've seen more octagon ones than square ones
Chug
Postby MinorMatt » Wed May 14, 2025 1:55 pm
The mk4s had a jack handle with a square on the end. That square was the drive for both the spare wheel and the jack.
The mk5s have a jack handle with a square on the end, but there is a recessed octagon on the end of the square. The square drives the jack, the octagon lowers the spare.
What you have pictured is the mk5 type
I might have a spare handle knocking around
Postby MinorMatt » Wed May 14, 2025 4:36 pm
This is what you need. I have checked it has the drive with the seller...
https://ebay.us/m/sNZwyc
Postby Kiwi MAN » Thu May 15, 2025 5:49 am
Thanks everyone. I'll be back in the UK in a couple of weeks, so I know what I'll be bringing back with me!
Kiwi MAN
Postby Kiwi MAN » Mon May 19, 2025 7:16 am
MinorMatt wrote:This is what you need. I have checked it has the drive with the seller...
Thanks - I've bought the handle and will collect it from my parents house when I'm back in the UK next month.
Now I'm wondering what other 'rare' bits I should look out for...
Cheers,
Mark,
Wellington, NZ.
Kiwi MAN
