1998 2.5d pump adjustment
Postby Transit in France » Sat May 10, 2025 1:19 pm
Hi, Ive a 1998 2.5d with Bosch pump pumping out black smoke under load and high revs. Ive been told I need to turn the pump down. My question is the adjustment screw at the back of the pump hiden by the security/Pump bracket? Thanks for any info.
Transit in France
Re: 1998 2.5d pump adjustment
Postby Altransit » Sat May 10, 2025 4:41 pm
The one at the back (near the pipes) adjusts Max fuelling, (sounds like yours is turned up too much)
The one under the cap on top adjusts Mid Range fuelling, (which can give you a useful increase in torque) can also create black smoke if overdone.
Only adjust both in small amounts as there is no reference point to go back to :wink:
Postby V184 » Tue May 20, 2025 4:14 pm
Transit in France wrote:Hi, Ive a 1998 2.5d with Bosch pump pumping out black smoke under load and high revs. Ive been told I need to turn the pump down. My question is the adjustment screw at the back of the pump hiden by the security/Pump bracket? Thanks for any info.
You sure its not an egr or air filter fault ?
V184
