Hi everyone,
Another weekend of tinkering on the 1996 Mk5 high-top campervan.
One job was to remove the broad rubber strip across the top of the windscreen that was not sitting flat. I expected this to have been pushed out by rust and covering some holes, but it's remarkably good underneath.
The rubber strip and the stainless steel insert have cleaned up well and the area above the windscreen and on to the roof are looking good.
But how do I fix the strip back on the van? It was previously held on with sealant - but there seems to be the ancient remains of some screws also, that were not holding anything.
Should I fix it back on with windscreen sealant, double sided tape or are there meant to be clips to attach it?
Thanks,
Mark, Wellington NZ.
