Hello together!
Has anyone a source for new drum brakes for my rear axle? I could not find any on the web.. I am searching for drums with the following specs:
Hight 146,0mm
Center 130.0mm
Outer diameter 292.0mm
Inner diameter 254.0mm
Inner diameter max. 256,0mm
Inner Hight 83,8mm
So those are the numbers I could research:
76VB-1126-AB FORD
76VB-1126-AS FORD
76VB-1126-AT FORD
86VB-1126-TB FORD
1 427 965 FORD
1 545 199 FORD
6.049.432 FORD
6 109 245 FORD
6 166 059 FORD
6 166 060 FORD
6154571 FORD
A.B.S. 3343-S
FORD: 1406129_ALT
FORD: 1545199_ALT
FORD: 6049432
76VB1126AS
Delphi: BF172
SBS: 262507
FORD: 1427965
812016214
Guttmann: BDR71029
FORD: 6109245
FORD: 6154571 / 86VB1126TA
FORD: 6166059 / 86VB1126TB
NDR037 30-225-009 / 30225009
BS14164 / BS 14164
BBR7110
Motomobil: 14279650
