Good morning.
98 2.5 TDi Auto Box
Engine light came on about one week ago just as we were getting home so pulled into drive and now have time to check what’s up. Have read various related threads leading me to find plug at back of EPIC pump was full of water, now dried out and WD40’d, checked timing with pins which is all good. Every time I start engine light comes on and stays on but if I start engine with foot on accelerator engine will rev but light is still on, as soon as I lift foot off accelerator limp mode kicks in and engine will no longer rev still with light on. Every so often engine will self rev to flat out and needle is now stuck at around 7000rpm (way past the 6000 limit!).
If it is an EPIC pump issue is it correct that a BOSCH conversion is not possible with auto box.
Any other pointers gratefully received.
I do have a pretty good local garage for older vans so al is not lost if i cannot figure it out myself.
Thanks in advance.
