Thanks for taking the time to help. I am sorry in advance but for clarity the explananation is a little long, and my speeling is not good....
The handbreak started acting strange by locking in different positions and then locked up totally. when I took the drums off the break material fell out of the drums, not the shoes just the sheets of breaking material in complete sheets
So I fitted new shoes, new wheel cylinders, bled the entire circuits ( 2 litres of DOT 4) just to ensure a fresh start for the rear brakes. (The front had been done a couple of monthes prior.)
when I come to use the breaks the pedal hits floor, pump pedal and it becomes stiffer (not solid) then sinks to the floor and there is very little resistance and no stopping power on the hydraulic circuit, just the handbreak.
No visable leaks no servo hissing same result with or without engine running so I assume that the servo is not the fault its the master cylinder (M.C.) I am sumising that the M.C. could not handle the extremes and popped the internals.
Drained the M.C. removed the M.C. cleaned it all externally and tried to bench strip.
Haynes says that this cylinder is not serviceable but I remove the spring clip and removed the plastic disk behind the clip and i am then faced with a blank plate with the pushrod going through the middle. nothing I tried would make it come out thus I was unable to determine the internal fault.
So I put it all together and have been trying for a couple of weeks to find one under £200 I was a welder fabricator by proffesion but it took too much of a toll on my body so I am registered disabled and dont have the money and that is why I cant afford garages or hundreds to throw at this.
When you said about clipping the two terminals on the obd port which pins do i short to enable the codes to flash out?
