What should I do? Any advice welcomed
Postby npjrogers » Sat Aug 02, 2025 5:07 pm
I have a 96 non Banana 2.5DI swb Motorhome. Bodywork is excellent. 117k miles. Just did timing belt and new water pump after a major coolant leak (which I thought was the water pump) turns out it seems to be a head gasket but with no white smoke and no milky oil. The water forms a bead just above the front end of the exhaust manifold and under the big air tube. It only appears when the engine is hot and when running at higher revs. Although I managed the timing belt and pump I have too many birthdays to embark on a head gasket job.. If it is a head gasket should I spend the money on a reconditioned TDI replacement engine or get a garage to fix the existing DI engine? Sorry for the long post but any advice would be most welcome.
Sic Transit Gloria
npjrogers
Re: What should I do? Any advice welcomed
Postby V184 » Sat Aug 02, 2025 9:27 pm
npjrogers wrote:I have a 96 non Banana 2.5DI swb Motorhome. Bodywork is excellent. 117k miles. Just did timing belt and new water pump after a major coolant leak (which I thought was the water pump) turns out it seems to be a head gasket but with no white smoke and no milky oil. The water forms a bead just above the front end of the exhaust manifold and under the big air tube. It only appears when the engine is hot and when running at higher revs. Although I managed the timing belt and pump I have too many birthdays to embark on a head gasket job.. If it is a head gasket should I spend the money on a reconditioned TDI replacement engine or get a garage to fix the existing DI engine? Sorry for the long post but any advice would be most welcome.
Sure its not the heater hose or the union at the front of head?
V184
Postby npjrogers » Sun Aug 03, 2025 9:04 am
I really appreciate your advice.. that has given me feeling of hope!.. I will do a detailed follow-up check.. as you can appreciate the leak is on the hot side of the engine.. it appears to form a little bead about the size of a pearl and then dribbles down onto the hot exhaust and evaporates.. seems to only happen when the engine is hot and presumably the thermostat is open..
Again thanks for sharing your experience.. Have a good day..
Nick Rogers, Lisburn, N.Ireland
Sic Transit Gloria
npjrogers
Postby dumper » Sun Aug 03, 2025 7:43 pm
Try and get a pressure tester on it
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby npjrogers » Mon Aug 04, 2025 4:38 pm
Thanks for your advice.. the leak is on the heater hose (inlet) it spurts against the rocker cover when the engine is hot and runs down onto the hot exhaust manifold.. I have ordered a new hose Metzger 2420084…. The challenge will be to get at the bulkhead connection on the heater box.. I understand that there is a little blue plastic tool that allows you to turn the white coupling anti-clockwise to release the pipe.. will I need to do a major strip down for access to the heater box inlet stub pipe?
Thanks all
Nick
Sic Transit Gloria
npjrogers
Postby dumper » Mon Aug 04, 2025 5:46 pm
From memory it’s take the air filter off not 100% sure but in the past I think I I removed the clip setup off the pipe stub and refitted the pipe with a jubilee clip I could be wrong as it was 25 years ago
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby V184 » Mon Aug 04, 2025 10:15 pm
npjrogers wrote:Thanks for your advice.. the leak is on the heater hose (inlet) it spurts against the rocker cover when the engine is hot and runs down onto the hot exhaust manifold.. I have ordered a new hose Metzger 2420084…. The challenge will be to get at the bulkhead connection on the heater box.. I understand that there is a little blue plastic tool that allows you to turn the white coupling anti-clockwise to release the pipe.. will I need to do a major strip down for access to the heater box inlet stub pipe?
Thanks all
Nick
From memory you can carefully cut the plastic retainer off with a stanley knife
V184
