Diesel heater fitment - OK to cut fuel lines
Postby mk3_wrc » Mon Sep 22, 2025 5:12 pm
Fitting a diesel heater to the van, is the flow pipe OK to cut (which is it likely to be...?) just as it comes from the tank (without needing to drop the tank). Somewhere between the tank and the loops:
Will fit a NRV as close to new T/Y piece as I can.
2000 Transit 190 LWB 2.5di Turbo - Coachbuilt motorhome
mk3_wrc
Re: Diesel heater fitment - OK to cut fuel lines
Postby dumper » Tue Sep 23, 2025 9:15 am
On both my x BT vans they were teed in to the main fuel line if you trace the fuel line from the lift pump under the van you will see it enter the tank I think the pipe is joined just in front of the tank as it comes in two pieces if not cut it there and fit the tee
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby MinorMatt » Tue Sep 23, 2025 9:55 am
Yes you can Tee in.
Its what Ford themselves did on my highcube
Postby mk3_wrc » Wed Sep 24, 2025 8:49 pm
That picture is just forward of the fuel tank from the lifter so ill splice there and just put a NRV on each side of the T.
mk3_wrc
