Hello people.
Havn,t been on this site for some time as everything has been running smoothly. I have a 1996 2.4 turbo transit. I have utilised the second battery space to add a standard 12 volt battery with isolator between as I occasionally go camping and use 2nd battery for internal lights only. After my last trip the van was stood for a couple of weeks and when I went to start, the battery was dead flat. Fitted a brand new battery and now this has done the same thing. Both batteries show 14.3 volts when engine running. Isolator is supposed to prevent "main" battery from being drained. Obviously a Drain from somewhere anyone got idea? System has ran for a number of years without any problem.Only electricl issue I have ever had is starter solenoid occasionaly, twice in 12 months, stuck and required tap to clear. Suggestion please !
