Oil cooler came off with the oil filter
Postby Kiwi MAN » Sat Oct 25, 2025 11:00 am
What could be easier than an oil and filter change?
The filter would not come off by hand, or with a filter spanner, or with a strap wrench. In desperation decided to try the 'screwdriver through the filter' method, which failed miserably - it just tore up the filter case, leaving just the base plate.
So, getting 'creative' out of frustration, out came the cold chisel, mole grips, crow bar and hacksaw. Finally this got filter moving, but it also unscrewed the pipe through the oil cooler. I was thinking that the filter was stuck on the outside gasket, but it was the inside threads that were solid - had to put the remains of the filter in a vice to finally remove it from the pipe.
The remains -
The next 'easy' job was then to refit the pipe through the oil cooler. This is screwed in by a 13mm (maybe 1/2"?) hex drive, which I don't have. So, visited every hardware and motor parts store in the area and there are only 12mm or 14mm options - no one has a 13mm.
Before I buy a 14mm hex driver and modify it with a grinder - is there anything I'm missing here?
Simple jobs rarely are, but this one has got me questioning my sanity.
Cheers,
Mark,
Wellington NZ.
1996 LWB High-top camper.
Kiwi MAN
Re: Oil cooler came off with the oil filter
Postby MinorMatt » Mon Oct 27, 2025 10:49 am
Took a minute... but I've just worked out what you are talking about
I'm sure it should be a 14mm one - but clearly you have found its not! H13 bits are not hard to get over here at all... but nothing stopping you adjusting a 14 to suit!
A friend of mine installed one with just mole grips
Postby Kiwi MAN » Thu Oct 30, 2025 11:18 am
Thanks,
In the end, I found a neighbour who had a 13mm Allen key.
I've never had other parts of the engine come off with an oil filter before.
Kiwi MAN
cron
