Fitting a priming bulb
Postby mk3_wrc » Sat Nov 01, 2025 6:16 pm
Hi all,
I've got a van with an epic pump.
I ran out of fuel.
I can't get it primed. I bought a new fuel filter and filled it with diesel, I've cracked all the injectors but no fuel coming out. Cranked for probably a total of about 240 seconds over the past week.
Took the feed pipe off the filter housing and cranked and it spaffed diesel all over so its definitely feeding from the lift pump.
Where would one fit a priming bulb? Or another method? Pressuring the tank by way of a foot pump or something somehow?
TIA.
2000 Transit 190 LWB 2.5di Turbo - Coachbuilt motorhome
mk3_wrc
Re: Fitting a priming bulb
Postby V184 » Sat Nov 01, 2025 7:17 pm
Sounds like an injection pump problem
V184
Postby mk3_wrc » Sat Nov 01, 2025 10:24 pm
Hope not... on 46k miles full service history and no issues prior to this.
I have since managed to get fuel to the injectors but it seems fizzy?? Maybe a fitting not done up right...
mk3_wrc
Postby Chug » Sat Nov 01, 2025 10:58 pm
It's probably air in the system, epics can be a pain to bleed, the fizzy fuel at the injectors seems to indicate air, have you got any easy start or someone who can give you a tow?
Chug
Postby mk3_wrc » Sun Nov 02, 2025 9:30 am
Easy start yes, someone to tow no. Its 3.1t with me in it so would need something with a decent towbar lol.
Will give easy start a blast.
mk3_wrc
Postby mk3_wrc » Sun Nov 02, 2025 1:00 pm
Few squirts of easy start with injector 2 cracked and she sparked up and back to its usual silky smooth purr :lol:
mk3_wrc
