Rear hub seal and large halfshaft seal Nightmare
Postby savi18 » Tue Jan 20, 2026 6:16 am
Found my offside rear hub leaking oil after inspecting the rear brakes, reading threw the Haynes Manual for this 1997 mk5 Transit bus with single wheel 14'', its states 2 1/2 inch socket which is 57.15 mm for the socket, the nut is a double hexagon nut, other sites I've been on sites mentions it 65mm socket, i think its a H axle. please tell me what size socket as don't want to go and buy wrong socket,
Could someone point me in the right direction to locate and buy the hub seal and also the very large thin seal that's fits on the Half shaft where it rest against the hub when refitting the shaft, spent ages looking for information but very conflicting information. Vin No SFAEXXBDVEVJ31353 if its helps, Cheers savi18, ps: i live in NZ now so parts here are non existent.
savi18
Re: Rear hub seal and large halfshaft seal Nightmare
Postby MinorMatt » Tue Jan 20, 2026 2:07 pm
The hub nut is 56mm bi hex on (pre 2000) transits with 5 stud wheels (as yours is).
Its 65mm bi hex for 6 stud wheels (single and twin)
Postby MinorMatt » Tue Jan 20, 2026 2:11 pm
With regards to the seal between half shaft and flange, there is an O ring there... part no is 1402712 and it sometimes comes in a wheel bearing kit.
https://www.catcar.info/ford/?lang=en&l ... YrMA%3D%3D
Postby savi18 » Wed Jan 21, 2026 6:50 am
MinorMatt wrote:The hub nut is 56mm bi hex on (pre 2000) transits with 5 stud wheels (as yours is).
Thankyou much needed information.
Cheers
savi18
savi18
Postby savi18 » Fri May 08, 2026 7:59 pm
Hi Team, got my Rear hub seals and 56mm Socket eventually, can I reuse the 56mm hub nut and torque settings please for retighting,in the Haynes Manual it says 440Nm or 325 lbf ft but cant trust those settings, will be using locktite on the nut thread, 1998 2.5d Toureo 14" wheel's
savi18
Postby dumper » Fri May 08, 2026 8:17 pm
I have reused them if no damage when we got the kit with nut and seal in them the nut was never right don’t go mad on the locktight with them not being preloaded used to do do them up FT
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby savi18 » Fri May 08, 2026 8:38 pm
dumper wrote:I have reused them if no damage when we got the kit with nut and seal in them the nut was never right don’t go mad on the locktight with them not being preloaded used to do do them up FT
What torque did you set the nut at, Cheers
savi18
Postby dumper » Sat May 09, 2026 7:25 am
FT is a swearword and tight :D
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
